11-11-2010, 07:02 PM
Not my lucky day! I have two Comfort installations: one at home and one at the office, each with their independent UCM and connected wirelessly to the same network. In a bout of bad luck, my router packed while I was updating my home Comfort configuration file, meaning that the transfer PC -> Comfort was cut off half-way. Now my Comfort at home is dead!
When I turn it on, all my 4 keypads are powered but don\'t have communication with Comfort (they make a soft continuous beep-beep sound), my strobe keeps flashing, my ethernet UCM (firmware UCM 5.156) is not accessible (with RDY LED on & D102 LED blinking & D103 occasionally blinking), my main board (PC01-070A, with firmware ULT 5.164) has a steady green LED on but my second output board (PC01-050B) has alternating Red & Green LEDs on, if I press Reset nothing happens.
Using my UCM I copied the NVM of my working Comfort (office) to the NVM of the dead Comfort (home) with success, but when putting the home NVM back Comfort was still dead.
I then put the home NVM into the office Comfort board (with no problem, since it was a copy of the office NVM) and transfered the home settings from PC to office Comfort board, essentially loading the home NVM with the home settings via the office Comfort UCM/board (after transfer I verified that by entering the home code with no problem). But when putting the home NVM into the home Comfort board still the same problem remained, with all the symptoms described above.
It looks like Comfort is not starting, even after recovering the NVM from the interrupted transfer. A friend suggested me that there could be a problem with the boot loader?!
Any help please?! :-)
