Comfigurator 3.2.3 Beta
New Features
  1. New Splash Screen when Comfigurator is started. Uninstall the previous version of Comfigurator before installing the new one in order to see the new splash screen
  2. Velbus can support 512 channels (was 330)
  3. Support for Universal UCM (under development)
Bug Fixes
  1. Read From Comfort with \"Keep Names\" Option causede exception
  2. Double-clicking Number of Slaves in Modules & Settings caused an exception
  3. Right click on an empty Response caused Exception.
  4. Opening a Recent File which has been deleted caused an Exception
Known Issues
  1. Bus Monitor and IR Learner are still under testing
  2. Comfort I firmware 4.230 has a problem with Comfigurator 3 when using Branch actions. Min version for Branch actions is 4.232 but Comfigurator is not able to transfer to Comfort with 4.230
  3. In KT03, changing the Font size of text in Button Element causes an exception
  4. For Velbus, if a blank EEPROM is used in U2, an exception occurs aftre learning when writing to EEPROM
  5. Responses referenced by KT03 buttons are not shown as regerenced in blue
  6. In KT03 Comfigurator, Input zones allow Zones 1 to 64 but not RIO inputs 129 to 248
  7. KT03 simulator Home and Back jumps do not work correctly
  8. When Say Word Action is the last action in the Response, Comfigurator does not append another 255 to end the Response. hence if there are exactly 8 codes in the action including the 255 to terminate the Say words action, the Response will not terminate but continue into the next Response.. This is an existing bug even for older versions of Comfigurator. To work aorund, add a dummy action after the Say Word action.
  9. When Send RS232 Action is the last action in the Response, Comfigurator does not append another 255 to end the Response. hence if there are exactly 8 codes in the action including the 255 to terminate the  action, the Response will not terminate but continue into the next Response.. This is an existing bug even for older versions of Comfigurator. To work aorund, add a dummy action after the Send RS232 action. Applies to CBUS and KNX actions
  10. IR Receive Responses - if assigned to NULL, will call Response 255 if the IR signal is received. To workaround, do not use Response Number 255
  11. Reading a ccl file with less than 8  UCM will cause 8 UCMs to appear in the Modules Tab. The Numver of UCMs in Modules and Settings will not be 8. However when you change the name of a UCM or delete a UCM in the Modules tab then the number of UCMs in Modules and Settings will change to the wrong number.
  12. If the Sound Type Name is changed, the Siren Type which points to the sound type is not updated
Please download beta version from https://www.cytech.biz/comfigurator.html
A bug has been discovered for 3.2.3 and probably older versions of Comfigurator
This will be fixed in the next version of Comfigurator
Many thanks to  barn1994 who reported the problem in http://www.comfortforums.com/view_topic.php?id=2022&forum_id=69
