Velbus Temperature Control
How it should be the responce that comfort announce the temperature value correctly?
I try this one:
Get sensor register
Say Degrees
I\'ll try to calibrate the value (i change it to 7,5) from velbus link but i thinks its not the correct way.
First, add one UCM as Velbus type in Comfigurator > Modules tab > UCM\'s.
Then on the UCM/Velbus page, go to \'Velbus to Comfort\' tab and Add the temperature sensor module (currently support VMB1TS) and assign it to one of the Sensors in Comfort.
When the sensor Register is updated with a new value from Velbus, it also activates the Sensor Response in Comfort tab > Events > Sensor Responses; hence put the announce temperature response here.
I did this, but what is the response that should fix it?
In your first post,
Get Sensor Register #
Say Degrees
are the correct actions to put inside the Sensor Response.
Take note that Sensor Responses will only be triggered upon a change in temperature.
If you want the temperature to be announced in other situation, you can put the response in other event, let\'s say in one of the scene button on Comfort RC01 remote control.
keypad only announced \"zero degrees\"
I just sent the cclx file to support for check.
