UCM does not works...
Hello and first of all, scuse me for my bad english.....
Well, i am trying to install the Cytech system, but it seems to be a little difficult...
After installing everything, today i have powered on the system, but i have some problems.
The wall-keypads, beeps continuosly as i press a key... ok.
Ten the keypads screen shows \'Id1\' and \'id2\'.
I have connected pc via rs232 to UCM (5.1), but no possible to communicate.
Well, the leds D9 and D10 are off.
The jumpers are set to id1 and everything seems to be right connected, but the leds does not blinks..... they are off.
What can i try to do?
Thank you and scuse me for my bad english.
Ema from Italy
Hi Ema. Nice to hear from Italy
The Keypads only showing ID1 and ID2 means that the Rs485 wires KA and KB are not connected to Comfort.
UCM D9 and D10 not blinking also means that KA and KB are not connected
Check the KA and KB from Comfort is connected to the Keypads and UCM
You can use the white 4 way cable to connect between Comfort and the UCM
Be careful not to reverse KA and KB, ie make sure KA is connected to KA and KB to KB
Hello and many thanks for your fast reply....
Today early in the morning, i have read it and so, i ran at home and i have spent all the day trying to solve the problem.
I have checked Ka and Kb connections and they seems really to be ok.....
I have read and read and read installation manual, but..... problem not solved.
After an entire day long, i am really becoming crazy.
I don\'t know how can i more do......
By any chance, did you connect the 6-way programming cable from the UCM to Comfort board?
The programming cable has coloured wires as follow: red, black, white, orange, yellow, and green.
Note that the programming cable shall NOT be connected to Comfort under normal operation.
Well, i did connect 3 cables:
One cable is 4-wire red, black, empty, empty, white, orange and is connected on a 6pin connector near to wich i can read \'program\'.
It seems the \'programming cable\' you told, but it has only 4 wire, not 6.
Another cable i have connected is a 2-wire cable white, orange, placed to the left-up (PP3 C6).
Last cable obviously is Jp2.
First i have disconnected the programing calble and i have tryed to reset, then i have disconnected both cable and i have tryed to reset, buth in every 2 conditions, Ucm leds are all off and on the keypads, now, the green led \'off\' is on, the red led \'Arm\' is blinking and on the lcd screen nothing is reported.
[user=1490]hendy[/user] wrote:
Quote:By any chance, did you connect the 6-way programming cable from the UCM to Comfort board?
Yes, programming cable is different in its two ends.
One end is 6-way cable.
Another end is 4-way plus 2-way cable.
This programming cable is only used when doing firmware upgrade.
The last cable that is connected to JP2 of UCM module is the right cable.
But where the other end of this cable you connect to?
It should be connected to the 4-pin connector on Comfort board labeled as RS485.
After connecting this cable, press the RESET button on Comfort board.
The green D1 LED on the UCM module should turn steady on and D9, D10 are flashing fast.
...... i have a little suspect.....
What is the module \'PC01 039a\'?......
\'Aux dist module\'...
Auxiliary Distribution Module is a module which allows more connections from
UCMs, Keypads, Door Stations and other Comfort Modules to be connected to
Comfort.
If you still have problems you can send a photo of the board and connections to support@cytech.biz
Ok, the problem seems solved!
I did some big errors in connections. The problem is i don\'t speak english very well, so it\'s a little difficult to me to understand the manual....
.....but now i have another problem......Sad
Well, every leds on the system is ok.
I have connected my laptop in order to download configuration.
Connection between Pc and Cp9000 is estabilished and some messages appares on the screen:
1) \"Setting system clock with pc clock?\" ....Yes...
2) \"The File Sysem 18 is not compatible with this version. Continue anyway?\"...... hmmmmm.
Well, trying to continue, the download does not continue.
So i have tryed to convert the file system to 17. Same result. I have tryed every possible number of file system, but the result is the same.
At the end, i have tryed to return to the file system 18 and this too does not works now.....
Am i a real disaster?....
