ComfortClient / Plugins / Connectors / Addons
I\'ve started this thread as a landing zone for the latest posted versions of the ComfortClient and supporting applications. You can also download from my website at: https://www.futurehomesoftware.com ComfortClient:
Quote:ComfortClient:
Quote:https://www.futurehomesoftware.com/releases/ComfortClient-Setup-5.1.6.2.exe
Quote:Sounds for ComfortClient - Myma**:
Quote:https://www.futurehomesoftware.com/releases/Comfort-Myma-Sounds-Setup-1.0.3.zip
Quote:Sounds for ComfortClient - Kate**:
Quote:https://www.futurehomesoftware.com/releases/Comfort-Kate-Sounds-Setup-1.0.3.zip
Quote:OpenXML Plugin for ComfortClient and Modbus Plugin:
Quote:https://www.futurehomesoftware.com/releases/OpenXml.zip
Quote:GaugePack 1 Add-on for ComfortClient:
Quote:https://www.futurehomesoftware.com/releases/GaugePack1.zip
Note: ** The contents of these packages (WAV Files) are copyright Cytech. I\'ve packaged them in an installer that simply copies them in the correct folder location for the ComfortClient. You can also download these as seperate WAV files from the Cytech web site. Plugins:
Quote:Modbus Plugin for ComfortClient:
Quote:https://www.futurehomesoftware.com/releases/Modbus-Setup-4.1.3.1.exe
Quote:World Weather Plugin for ComfortClient:
Quote:https://www.futurehomesoftware.com/releases/WorldWeather-Setup-2.1.3.1.exe
Quote:Data Monitor Plugin for ComfortClient:
Quote:https://www.futurehomesoftware.com/releases/DataMonitor-Setup-2.1.3.1.exe
Quote:Current Cost Plugin for ComfortClient:
Quote:https://www.futurehomesoftware.com/releases/CurrentCost-Setup-1.0.3.1.exe
[size=3]Connectors:
Quote:Application Connector for ComfortClient:
Quote:Included in ComfortClient distribution
Quote:Microsoft SQL Server Connector for ComfortClient:
Quote:https://www.futurehomesoftware.com/releases/MSSQLConnector-Setup-1.0.2.1.exe
Quote:MySQL Connector for ComfortClient:
Quote:https://www.futurehomesoftware.com/releases/MySQLConnector-Setup-1.0.2.1.exe
Version History:[/size]
Quote:https://www.futurehomesoftware.com/releases/ComfortClient-Revision-History.pdf
Quote:https://www.futurehomesoftware.com/releases/ModbusPlugin-Revision-History.pdf
Quote:https://www.futurehomesoftware.com/releases/WorldWeatherPlugin-Revision-History.pdf
Quote:https://www.futurehomesoftware.com/releases/DataMonitorPlugin-Revision-History.pdf
Quote:https://www.futurehomesoftware.com/releases/CurrentCostPlugin-Revision-History.pdf
