Threads: 55
07-27-2010, 07:35 AM
(This post was last modified: 07-27-2010, 12:28 PM by TheMax74.)
If possible, i need these two responses when Comfort starts to speak and when it ends speaking.
Using a KNX multiroom system from WHD or Gira and an UCM/Audio, i can, for example, switch on or off one or more zones based on \"speaking\" responses and forward the audio from UCM/Audio to these zones.
Thanks.
Threads: 885
If I understand correctly you want to have announcements on an external KNX sound system
We cannot activate responses beased on start speaking and stop speaking
However for the KNX configurator, Comfort > KNX screen you can map a group address to the Keypad speaker so that when the speaker of the keypad turns on the assigned group adddres turns on and vice versa
This allows an external speaker to be turned on during a keypad announcement
This is a planned feature which has not been implemented yet
Threads: 55
\"However for the KNX configurator, Comfort > KNX screen you can map a group address to the Keypad speaker so that when the speaker of the keypad turns on the assigned group adddres turns on and vice versa\"
That\'s exactly what i need. I will use group address instead of responses.
Thank you.
