PIRs in Night mode
How do I or what do I set my sensors to allow for night mode. I have 15 zones of which all are PIR\'s. How do I set the system at night to allow me to disable certain sensors i.e. beedroom. This is to allow movement in certain areas.
You can determine the behaviour of the PIRs in Night Mode by selecting the Zone Type.
Use Zone Type PIR Away if the zone is active only in Away Mode, like in the bedrooms and other areas where people need to move around
Use Zone Type PIR Night Away if the zone is active in Away and Night modes
In Day mode these two zone types are not active
On the keypad, arm to day mode for all PIRs to be inactive. Arm to Night mode for PIRs in PIR Night Away to be active, arm to Away Mode for all PIRs to be active
Cheers, just tried this and the problem has been sorted. Thanks.
I want to program the following:l
How must the Zone Type look if :
The outside pir\'s must still say zone name always, in away,night,sec.off etc.
I don\'t know if it must be immediate,perimeter etc
Sorry for this easy question.... i\'m still knew in this game
PIRs are normally programmed as PIRAway or PIRNightAway zone type.
PIRAway means it is enabled only in Away mode and disabled in other modes.
PIRNightAway means it is enabled both in Night and Away modes.
Zone name announcement can be triggered by creating a response (which has \'Say ZoneName\' action) put under the PIR\'s zone On Response.
4 Guest(s)
