Threads: 62
Is there a way to disable the Arming and Disarming tones from being output on the DS?
When arming the DS gives one beep and when disarming the DS gives the 1s interval beeps similar to a keypad. If it cannot be disabled can I then set the volume of these two actions down to a minimum?
Ingo
Threads: 880
In Modules > Configuration Flags there is a checkbox for \"Disable Arming Voice on Door Stations\" which disables voice and tones
Threads: 62
That flag has been set already. When disarming from away mode I hear loud beeps, the same as my keypad. Is there a way to stop them?
Ingo
Threads: 880
We do not hear the arming tones at the door station while arming. However the slow beeps are heard during Entry Alert when the front door is opened. Are you sure you can hear the arming beeps?
To disable the entry alert beeps at the door station go to Siren Types > Arming Tone, uncheck Door Phone for this siren
Threads: 62
Chiu,
The arming tones are not there but there is one \'beep\' when you arm to away mode. This is the same volume as the disarming tones.
What I did was to disable all the DS \'Yes\' options except for the DoorBell function. This fixed both my issues, even one I haven\'t experienced yet - the AwayArmTrouble option.
Thanks very much.
Ingo
