Comfort Web Server
I have a web server that has been working for a while. Then it dont seems to work any longer as I could see the LEDs for the communication stops flashing. I\'ve checked the power and all other basic checks. Still cant get it back to work.
Any help would be appreciated.
With thanks,
Azar
When you say that the CWM\'s LEDs stop flashing, do you mean D9 and D10 which indicates the communication between the CWM and Comfort? Or do you refer to the Network LEDs which are at the side?
If it is the former, do you get communication failure on Comfort? Is the CWM powered up (veirfy the green RDY LED).
If it is the latter, could the network connection be loose? Or could the network be down? It could also be that the adpator is disconnected.
I am refering to the Network LED. Those D9 and D10 are working fine.
Thats what I didnt get when I power it up, the green LED which indicate ready is not lighted up. Well I have checked the adaptor power using a multimeter and seems to have power there.
Could it be possibile the CWM board is bad?
Thanks,
Azar
The LED will not be lit until the network cable is connected. Have you connected your network cable yet? Perhaps you could try connecting a cross cable from the CWM to a PC to test?
Yes the cable is connected when I check it. As I have mentioned it worked before. Just that now it does not work anymore and the thing that I notice is those Network LEDs are not flashing.
Azar
