Threads: 14
here is a sample from my monitor:
< CT7F00
< CTC900
< DT20100610040000
< DT20100610050000
< CTCBFF
< DT20100610060000
< DT20100610051505
is there any clue in this comfort was an hour out again this AM
I can disconnect comfort from cbus but a lot of things wont work
Mike
Threads: 885
From your I/O, It looks like after 06:00 the time was set to 05:15
I suspect Cbus is changing the time
Can you use the Cbus Diagnostic tool and monitor the Cbus activity in the same way?
Threads: 14
unit 31 is cbus ctouch
unit 253 is comfort ucm cbus
looks as if the cbus changed the time at 06:16:34
thanks
Mike
10/06/2010 04:02:18 C-Gate : Rx \"clock date //MGU/254/223 2010-06-10 3 #sourceunit=253 OID=\"
10/06/2010 04:02:18 Date/Time: Received C-Bus message to set date to 10/06/2010 (unit 253)
10/06/2010 04:02:19 C-Gate : Rx \"clock time //MGU/254/223 04:00:00 0 #sourceunit=253 OID=\"
10/06/2010 04:02:19 Date/Time: Received C-Bus message to set time to 04:00:00 (unit 253)
10/06/2010 05:01:22 C-Gate : Rx \"clock date //MGU/254/223 2010-06-10 3 #sourceunit=253 OID=\"
10/06/2010 05:01:22 Date/Time: Received C-Bus message to set date to 10/06/2010 (unit 253)
10/06/2010 05:01:22 C-Gate : Rx \"clock time //MGU/254/223 05:00:00 0 #sourceunit=253 OID=\"
10/06/2010 05:01:22 Date/Time: Received C-Bus message to set time to 05:00:00 (unit 253)
10/06/2010 06:01:25 C-Gate : Rx \"clock date //MGU/254/223 2010-06-10 3 #sourceunit=253 OID=\"
10/06/2010 06:01:25 Date/Time: Received C-Bus message to set date to 10/06/2010 (unit 253)
10/06/2010 06:01:25 C-Gate : Rx \"clock time //MGU/254/223 06:00:00 0 #sourceunit=253 OID=\"
10/06/2010 06:01:25 Date/Time: Received C-Bus message to set time to 06:00:00 (unit 253)
10/06/2010 06:16:34 C-Gate : Rx \"clock date //MGU/254/223 2010-06-10 3 #sourceunit=31 OID=\"
10/06/2010 06:16:34 Date/Time: Received C-Bus message to set date to 10/06/2010 (unit 31)
10/06/2010 06:16:34 C-Gate : Rx \"clock time //MGU/254/223 05:15:05 0 #sourceunit=31 OID=\"
10/06/2010 06:16:34 Date/Time: Received C-Bus message to set time to 05:15:05 (unit 31)
10/06/2010 06:16:35 C-Gate : Rx \"clock date //MGU/254/223 2010-06-10 3 #sourceunit=253 OID=\"
10/06/2010 06:16:35 Date/Time: Received C-Bus message to set date to 10/06/2010 (unit 253)
10/06/2010 06:16:35 C-Gate : Rx \"clock time //MGU/254/223 05:15:05 0 #sourceunit=253 OID=\"
10/06/2010 06:16:35 Date/Time: Received C-Bus message to set time to 05:15:05 (unit 253)
10/06/2010 07:01:32 C-Gate : Rx \"clock date //MGU/254/223 2010-06-10 3 #sourceunit=253 OID=\"
10/06/2010 07:01:32 Date/Time: Received C-Bus message to set date to 10/06/2010 (unit 253)
10/06/2010 07:01:32 C-Gate : Rx \"clock time //MGU/254/223 06:00:00 0 #sourceunit=253 OID=\"
10/06/2010 07:01:32 Date/Time: Received C-Bus message to set time to 06:00:00 (unit 253)
10/06/2010 08:01:37 C-Gate : Rx \"clock date //MGU/254/223 2010-06-10 3 #sourceunit=253 OID=\"
10/06/2010 08:01:37 Date/Time: Received C-Bus message to set date to 10/06/2010 (unit 253)
10/06/2010 08:01:37 C-Gate : Rx \"clock time //MGU/254/223 07:00:00 0 #sourceunit=253 OID=\"
10/06/2010 08:01:37 Date/Time: Received C-Bus message to set time to 07:00:00 (unit 253)
10/06/2010 08:31:18 C-Gate : Rx \"clock date //MGU/254/223 2010-06-10 3 #sourceunit=31 OID=\"
10/06/2010 08:31:18 Date/Time: Received C-Bus message to set date to 10/06/2010 (unit 31)
10/06/2010 08:31:18 C-Gate : Rx \"clock date //MGU/254/223 2010-06-10 3 #sourceunit=253 OID=\"
10/06/2010 08:31:18 Date/Time: Received C-Bus message to set date to 10/06/2010 (unit 253)
10/06/2010 08:31:18 C-Gate : Rx \"clock time //MGU/254/223 08:29:36 0 #sourceunit=253 OID=\"
10/06/2010 08:31:18 Date/Time: Received C-Bus message to set time to 08:29:36 (unit 253)
10/06/2010 09:01:43 C-Gate : Rx \"clock date //MGU/254/223 2010-06-10 3 #sourceunit=253 OID=\"
10/06/2010 09:01:43 Date/Time: Received C-Bus message to set date to 10/06/2010 (unit 253)
10/06/2010 09:01:44 C-Gate : Rx \"clock time //MGU/254/223 09:00:00 0 #sourceunit=253 OID=\"
10/06/2010 09:01:44 Date/Time: Received C-Bus message to set time to 09:00:00 (unit 253)
10/06/2010 10:01:49 C-Gate : Rx \"clock date //MGU/254/223 2010-06-10 3 #sourceunit=253 OID=\"
10/06/2010 10:01:49 Date/Time: Received C-Bus message to set date to 10/06/2010 (unit 253)
10/06/2010 10:01:49 C-Gate : Rx \"clock time //MGU/254/223 10:00:00 0 #sourceunit=253 OID=\"
10/06/2010 10:01:49 Date/Time: Received C-Bus message to set time to 10:00:00 (unit 253)
Threads: 62
Check the Cbus forums, they just released a ctouch fix which might solve your problem.
Ingo
Threads: 14
thanx for the heads up
I\'m now running 4.8.4 Piced
Mike
