Is the 'Measurement Application' supported?
I was wondering if the CBus \'Measurement Application\' is supported, it\'s application 228 ($E4).
Can I send the following command to my UCM/Cbus: 197,18,1,2,20,228,255
I am trying to send a value of 20 to the CBus side on application 228. Once I get that right then maybe I can use the Measurement Application to read the values sent from Comfort.
Ingo.
Yes you can send a message to any application in C-Bus
That series of codes is equivalent to Cbus RampInst 2 1 20 228, ie Instantaneuous Ramp to level 20 on Group address 1 for Applocation 228
I now see that the Measurement Application has an entirly different format to the Lighting application. Sending a Measurement Application message in a Lighting Application format will not work, there are too many differences between the two.
Please find the Measurement Application documentation here http://training.clipsal.com/downloads/Op...cation.pdf
The Response wizard does not support this. They did not have these details when the UCM/Cbbus was developed
What is your application?
Thanks for the update, I will wait for a future firmware update that might support this application then.
Regards,
Ingo
4 Guest(s)
