The screenshots show an example of the power of the UCM/KNX when used with a KNX Touchscreen, courtesy of Domotiks, our distributor in Spain
The Comfort keypad can be simulated on the touchscreen allowing the user to enter their Comfort user code to arm and disarm the security system just like a real keypad!
The user code is the same as on Comfort. if the user changes the code, then the same code must be used on the KNX touchscreen. In other words KNX does not keep the user code, thus leading to greater security. Note: use 1 byte Datapoint Type 5.010 type in ETS for the keypad keys
The security mode buttons Away, Night, day, Vacation can be used to arm the securty system, and the buttons also show the actual security mode, for example if Comfort was armed by another keypad to Night Mode, the Night mode button would show as active.
Comfort\'s Date and Time can also be shown on the touchscreen
