Comfigurator 3.1.8 is now released. This replaces the previous 3.1.3 version after extensive beta testing. This new version has many new features and productivity enhancements as well as bug fixes and improvement in stability and reduces Exceptions. It is highly recommended to upgrade the sotfware from http://www.cytech-technology.com/temp/so...r3.1.8.zip
Note that the change history is with reference to 3.1.3
Bugs Fixed
Bugs Fixed
- Fixed situations where in Reading from Comfort I systems, an Exception may be encountered due to various incompatibilities.
- Full Read from Comfort II also caused an Exception.
- \"Connected as PABX Extension\" flag did not get written to Comfort when Selective Write is used. In this version, Selective write for PABX Extension wil automatically Reset Comfort
- Import Responses does not overwrite existing flags and counter names now.
- Fixed - Configurator 2 files with CMS Account codes blank (0) caused exception when converted to Comfigurator 3 (.cclx)
- Fixed - Sunrise/Sunset Times> Daylight Savings times, if a city is not selected as location, and daylight saving is disabled, writing to Comfort will leave Daylight saving enabled, causing times to be incorrectly advanced by 1 hour. Workaround is always to select a city with the same time zone if Daylight saving is to be enabled.
- Fixed Modules and Settings > Wordlists changed to a non-English language, the Alarm Types Phrases are not matched to the language untill they are all assigned to the correct phrases in the language, resulting in the incorrect announcement and Display on the LCD of all Alarms
- For UCM/KNX Configurator, Adding KNX to UCMs will result in correct write to Comfort so KNX actions will work. See problem described in the KNX forum topic for more information
- RGR02/RGR03 checkbox is present for Comfort I File Systems
- In Modules and Settings Description on Number of Door stations, Slaves and SCS/RIo have been fixed
- Response Wizard If Counters value allow 255. Previously only 0-254 allowed
- Scan for UCMs erased all the information from the KNX Configration
- In an If/Then conditional action references a Do Response, and the name of the referenced Response is changed, the original Response order of actions was changed
- Eliminated errors in reading some Comfort configuraions
- Checking the LEM03 checkbox sets No of SEMs to 0 and setting No of SEMs >0 disables LEM03 checkbox as SEMs and LEM03 are mutually exclusive
- Drag/Drop works on Outputs just like Zones
- Edit > Autogenerate Names works on Counters and Sensors. In Events> Counter, Edit Autogenerate Names causes the Counter names to have the same name as the assigned Response. In Events> Sensor Responses, Edit Autogenerate Names causes the Sensor names to have the same name as the assigned Response. Note that Edit > Autogenerate also works on Responses and Zones individually.
- In Responses, Edit > Delete Unreferenced Responses (ie shown in Black instead of blue) allows removal of unused responses to make it easier to navigate.
- In Modules and Settings, when changing the number of UCMs, Keypads, SCS/RIO, Slaves, the Modules Tab (to the right of the Comfort Tab on the left pane) will show the added modules in the correct number, but assigned to a default Type eg KP04, UCM General. However when reducing the number of modules in Modules and Settings, the items in the Modules Tab are not reduced. This must be done manually. It is best to make any changes to the numbers of modules in the Modules Tab rather than in Modules and Settings screen
- Support for future Velbus Module in Response Wizard
- Read from Comfort will not populate the Modules Tab. This is a bug from older versions.
- Reading from Comfort without \"Keep Names\" option will show \"Invalid UCM Number\" errors in Responses concerning any UCM/KNX, UCM/Cbus or other external UCMs. However the Responses themselves will be correct even though the configuration does not know about the UCM numbers. Workaround is always to load the cclx file before reading and use the \"Keep names\" option
- In KNX Configurator, Monitor Mode does not work if the UCM number 1 is blank. This happens if a UCM which is not ID1 is used to connect to Comfort to do Monitor mode, but there is no UCM with ID=1 in the system. Workaround is to ensure UCM with ID=1 is always present in the system
- If any letter in a Response Name is changed from Capital to lowercase or vice versa, a Duplicate Name Error results. This is an bug from older versions
- For Phone Numbers to Dial out, CMS Phone Types are valid for Phones 1 and 2 only. Comfigurator allows CMS to be assigned to Phones 3 to 8 but this should be avoided. This is not a new issue, ie it has been this way since Comfigurartor 2, but will be fixed in the next version
- Response Wizard for Cbus Action; if Remote Network Bridges are specified, these cannot be deleted from the action, exceot by deleting the action
- Invalid IFR files in the existing IFR folder may cause Comfigurator to have an Exceotion when the program is run. To workarounf when Comfigurator has an exception when it is started, delete the IFR folder and reinstall Comfigurator
- IR Learner Utility in Windows 7 is not able to save the learned IFR file, see topic at http://www.comfortforums.com/view_topic.php?id=1827&forum_id=20
- IR Receive Responses - if assigned to NULL, will call Response 255 if the IR signal is received. To workaround, do not use Response Number 255
