Threads: 7
Hello,
I\'m still using comfigurator 2.1.0 on my Comfort panel.
Can I download and use version 3.1.3.0 ok without any problems or conversions?
regards,
Dave
Threads: 887
Comfigurator 3 and Comfigurator 2 can coexist on the same computer so there is no reason why you cannot start using Comfigurator 3, especially if you are programming your own system
You can always go back to Comfigurator 2 if you have any problems
Comfigurator 2.2.3 is the latest version of Comfigurator 2 so you should use that intead of 2.1,0
Threads: 7
Thanks Chiu,
So I can put 3.1.3 on my computer after removing 2.1.0 and then load in my ccl file and just programme as normal
Threads: 887
You can installl Comfiguraro 3 withiut having to uninstall Comfigurator 2
You can load a ccl file in Comfigurator 3 and 2 and program as normal
