Topic changed to SCS Question
Question on SCS
08-31-2006, 07:21 AM
I hope in am posting this in the right place. Just a quick question with regards to Comfort\'s RIO and Scene Switches. Each RIO/Scene switch has a unique address and has 8 SCSRIORESP and in the case of the scene switch only 4 can be used. Can I have two scene switches with the same SCS ID where the first one would use the first 4 SCSRIORESP and the second scene switch use the other 4 (I am using the Comfort Ultra) ? Thanks
08-31-2006, 08:46 AM
No you cannot use the last 4 switches in the SCS at present
We are shortly going to release a new range of 6 and 8 button scene control switches which make full use of the address. Details later
09-21-2006, 07:56 AM
I want to add a dimmer module to one of my outputs controlled from a Scene switch. If press the switch once it must toggle between On/Off (which it does currently) Is there a way that I can program the switch to cycle the dimmer module while holding the switch down (like a bell push) ? Thanks
09-21-2006, 10:06 AM
No, the scene switch triggers scenes only, it does not recognise the press and hold action
09-22-2006, 08:20 AM
I have set my SCS up to do four levels of dimming, using the two top buttons.
The levels are indicated by led\'s no led = off Left led = Low Both led = Mid right led = High Pressing the left button reduces the level and the right button increases it. I do this via a counter which increments/decrements as the button is pressed and sets the LED accordingly. I then use a two second delay before issuing the X10 command to set the lighting level which reduces the number of X10 commands and increases response speed as LED\'s set instantly but the required X10 commands take three seconds to send. This means going from low to high you would press the top right button twice, the led\'s would change as you press the button and as you step away, the lighting changes to suit. I have also used an X10 remote A1 on = off - A2 on = Low - A3 on = Mid - A4 on = High which allows the remote to work in quite a smart way. If you require further details, I can post the code I use. Darren
09-23-2006, 06:05 AM
Darren
Do you also use the X10 received commands to update the counters and set the leds accordingly when the lights are set by other switches or the remotes? That should be quite useful, could youi post the code you used?
09-26-2006, 10:39 AM
Chiu, I use a counter called Livingrmlightlev to control the dimming/scene in the living room.
The counter can have the following values 0=off, 1=low, 2=mid, 3=high. These are represented by the two top ledââ¬â¢s on the SCS [off - both LEDââ¬â¢s off, low - left LEDon, mid - both LEDââ¬â¢s on and high - right LED on]. I then use the left SCS button to reduce light level and the right button to increase it in the four stages. The light level is set by a response SetLivingRoom which sets the LEDââ¬â¢s and triggers the lighting VIA X10 to be set after 1second. This allows multiple presses to respond quickly without having to send X10 each time. Pressing the Dim button on the SCS this response runs If Counter Livingrmlightlev >= 1 Then Decrement Livingrmlightlev End If Do SetLivingRoom [Set's the state of the living room][/i] And Brighter runs this one If Counter Livingrmlightlev < 3 Then Increment Livingrmlightlev End If Do SetLivingRoom [Set's the state of the living room] [/i] To set the level directly from a remote control, I use this response (this turns the lighting off but setting the Livingrmlightlev counter to any of the numbers above sets the lighting to that level. Set Livingrmlightlev = 0 Do SetLivingRoom [Set's the state of the living room][/i] All of these methods of changing the lighting level change the Livingrmlightlev counter and run the SetLivingRoom response below which setââ¬â¢s the LED on the SCS and runs the appropriate light level response. LivingRoomDim and LivingRoomBright refer to the top left and right SCS LEDââ¬â¢s If Counter Livingrmlightlev = 0 Then Do Setlvrmoff [Set Living Room Off] After 1 Seconds Using Livingroomdelay Output LivingRoomDim Off Output LivingRoomBright Off End If If Counter Livingrmlightlev = 1 Then Do Setlvrm1 [Set Living Room Light Level1] After 1 Seconds Using Livingroomdelay Output LivingRoomDim On Output LivingRoomBright Off End If If Counter Livingrmlightlev = 2 Then Do Setlvrm2 [Set Living Room Light Level2] After 1 Seconds Using Livingroomdelay Output LivingRoomDim On Output LivingRoomBright On End If If Counter Livingrmlightlev = 3 Then Do Setlvrm3 [Set Living Room Light Level3] After 1 Seconds Using Livingroomdelay Output LivingRoomDim Off Output LivingRoomBright On End If [/i] Finally the response for setting the actual lights, this is run after a 1second delay to make the LED's responsive and reduce X10 traffic. My thought is you set the level on the SCS and then the lighting changes as you walk away. The response shown is for the mid level. X10 A7 and A8 are din rail dimmers where I use the preset dimming and A2 is a wall light that is either on at full or not. The 24 parameter on the first line is the preset dim level between 0 and 31. This would need tailoring to the specific requirement but I used 16 for low, 24 for mid and 31 for full. X10 Extended 24 49 X10 A7 Extended1 X10 Extended 24 49 X10 A8 Extended1 X10 A2 Off[/i] I have four of these responses, this is the mid response, these would need customising to the individual requirements. Hope this helps. Darren |
« Next Oldest | Next Newest »
