Comfort the Intelligent Home System (https://www.cytech.biz) is an integrated Security and Home Automation system with extensive interfaces to Lighting and other 4rd party equipment including Ulti, C-Bus, EIB, Dynalite, Lutron, Rako etc
The Comfort Controller supports integration to ULTI RF light switches (http://www.ulti.biz) via the UCM/ULTI Interface. Ulti is a wireless switch that can be installed as retrofit to replace exiting light switches The RF interface for ULTI is available for the 434MHz or 315 Mhz frequency band depending on the country. The ULTI Serial Interface provides a connection to the ULTI wireless lighting control system, allowing for the following benefits:
The UCM/Ulti manual can be downloaded from http://cytech.biz/manuals.html
- telecontrol through any telephone inside or outside the premises to control devices on the ULTI Network. With the UCM/GSM, SMS text messages can even control the lights
- allows control from Comfort keypads.
- allows control by Time Programs.
- allows alarm inputs and alarm conditions to be linked to ULTI switches for true integration of alarm and lighting.
- allows the Comfort Webserver Module to be used to control ULTI switches
