Threads: 476
The temperature sensor in the SCS I think it is not good solution. Is necessary included an SCS for to access the temperature sensors. An excellent solution I think is the creation of a new RIO (RIO02) with 8 inputs and 8 outputs analog (0 - 10V), so we can place sensors of temperature, light, humidity, etc..
Best Regards
Miguel Antunes
Threads: 476
What temperature sensors do you know which have 1 to 10 Volts outputs
Threads: 3
There was a temperature sensor module TCS01 in the list, is it foe the scene switch?
Threads: 885
TCS01 is the temperature sensor used in the Scene Cobtrol Switch. It is a PCB with the sensor without the plastic switch module. It has a SCS/RIO ID except that there are no buttons at a much lower price. The purpose is to measure the temperature and send it to a Sensor Register
Threads: 219
I think I was one of the first to use one of these in a project to measure outside temperature via a sensor register. They work really well IMHO.
