WizComfort Beta Version 1.9..0
The new version of WizComfort version 1.9.0 is ready for beta testing. It can be downloaded from  here
It will eventually be released as Wizcomfort 2.0
A new UCM Firmware UCM5.200 (beta) is required for WizComfort. Please download from http://www.comfortforums.com/forum81/1670.html
This supports the cclx file format used in Comfigurator 3. It has been completely redesigned using .NET.
This first version fits a 800x 600 screen typically used in touchscreens
Please post your comments in this forum
Update 27 May 2010
Wizcomfort 1.9.1 Beta is now available, see http://www.comfortforums.com/forum21/1860.html
i started to explore Wizcomfort , which i believe it is a good step to Enter Touchscreen interface with comfort, my comment so far for today is
- Wizcomfort is a softare for touch screen so i believe it need to be more color controlable by the user or to add more colors else than grey, as well as adding Icons to appliances identfication will be a nice touch, as well as ability to set a back ground picture by the user.
-IP Camera is based on URL and not drivers which is good for start, but only 4 Cams is a limited #, i believe 8-12 will do better job, as well as considering the drivers interface to has the ability to view all cams side by side at once which will be an added value.
-\"CLOSE\" button is really confusing, i kept restarting every time i want to minimize, i believe confirming \"Closing or minimizing\" will make it easier for users.
- my OS is Vista SP2/32-bit, every time i run the program and maximize it to full screen mode the Taskbar disappear and only start button is there, i tried over 6 PC restarts and it kept disappear.
- i use UCM / ethernet for interface, but i don\'t have any Voice communication, and when i press on the door station nothing appear on the program for visual informing as well i can\'t use \"Talk to Door station\" button to reply cause nothing in the drop down menu,  i did confirm that the door station is configured , and actually when i push the button (1) at Keypad Tab the communication open (Door station red button turned on ) but also no voice communication through the PC.
- Freezing Freezing, any wrong action it makes the programm Freez and stop responding without any informative msg, like when i entering regular URL at URL camera it accepted it but freez afterword, and sometimes it freez when logging out then logging in after changing some setting by configrator.
- Columns Width of buttons at Home control Menu reset to original unfitted size when i close the program and restart it , which i believe it is better to be auto fit or it memorize the last adjusted width.
- Voice communcation and messege recording using UCM/ethernet , i couldn\'t record or hear,  dose it need to define somthing like Mic driver ??
-if Wizcomfort is open i could open another and another as long as i click on the icon , i guess poping up message \" Wizcomfort alrady Open \" will be less confusing.
- why not add Home Control feature using floor plan as the webserver it will be a nice touch , but any way luanch a Bug free start version will be good, then upgrading afterward, even adding energy monitoring which may position the system at new spot .
i think that\'s my comment for now
cheers
- Taskbar Disappear if i close the Wizcomfort from Full screen mode, but if i did minmize to 800x600 then close, it dosen\'t .
more Graphocs gives a nice touch
Hi, i work for Segurant (Portugal), we are testing this Beta software and will send our feedback soon, is this an open source software? , can you share the .net code (Project)?
Keep the good work,
Best Regards, Jorge Colaço
Temperature display from defined SCS will add an informative data, as well Time & status Larger and and on top will be much seen.
Keep the Good Work Smile
[user=1991]WMADKOUR[/user] wrote
Quote:- i use UCM / ethernet for interface, but i don\'t have any Voice communication, and when i press on the door station nothing appear on the program for visual informing as well i can\'t use \"Talk to Door station\" button to reply cause nothing in the drop down menu,  i did confirm that the door station is configured , and actually when i push the button (1) at Keypad Tab the communication open (Door station red button turned on ) but also no voice communication through the PC.
Thanks for the feedback
To have audio you need to add the AUD01 plugin module
which plugs on to the UCM
The audio jacks connect to the mic and speaker jacks on the computer
You will be able to hear the voice like a real keypad and do recording and intercom
[user=2902]jorgecolaco[/user] wrote:
Quote:[size=\"3\"][font=\"Calibri\"]Hi, i work for Segurant (Portugal), we are testing this Beta software and will send our feedback soon, is this an open source software? , can you share the .net code (Project)?[/font][/size]
[size=\"3\"][font=\"Calibri\"]Keep the good work,[/font][/size]
[size=\"3\"][font=\"Calibri\"]Best Regards, Jorge Colaço[/font][/size]
This is not open source but let us know what your intention is
Wow! Very good job!!!
Is it possible to disable some Main Page buttons?, or any option that allow us to turn off some advanced functionalities. We want to give a basic interface to our clients that allow them to make basic changes to their system.
We are getting a few lag when turning ON some testing outputs (Tiny Lamps) using WizComfort, anyone have the same problem? we are using UCM 5.192 usb
Nice Job, keep going
17 Guest(s)
