UCM05 Firmware 5.174 to 5.192
Download UCM05 firmware upgrades from here
[size=\"4\"][font=\"Arial Black\"][font=\"Arial Black\"][font=\"Arial Black\"][font=\"Arial Black\"]Version 5.192 (28 July 2009)[/font][/font][/font][/font][/size]
  • [size=\"5\"][font=\"Arial Black\"][size=\"5\"][font=\"Arial Black\"][size=\"2\"][font=\"verdana\"]Implemented query S? for alarm state 0 to 3. Requires Comfort 5.173[/font][/size][/font][/size][/font][/size]
  • [size=\"5\"][font=\"Arial Black\"][size=\"5\"][font=\"Arial Black\"][size=\"2\"][font=\"verdana\"]If counter command from Comfort does not change the value of the counter, dont send CT to the UCM[/font][/size][/font][/size][/font][/size]
  • [size=\"5\"][font=\"Arial Black\"][size=\"5\"][font=\"Arial Black\"][size=\"2\"][font=\"verdana\"]Report BYzzss when zone zz is bypassed or unbypassed and B? query[/font][/size][/font][/size][/font][/size]
  • [size=\"5\"][font=\"Arial Black\"][size=\"5\"][font=\"Arial Black\"][size=\"2\"][font=\"verdana\"]Improved communications with Comfort immediately after UCM reset so that the initial commands are not missed.[/font][/size][/font][/size][/font][/size]
  • [size=\"5\"][font=\"Arial Black\"][size=\"5\"][font=\"Arial Black\"][size=\"2\"][font=\"verdana\"]Added F! Set Flag and F? Query and FL report commands Requires Comfort firmware 5.173[/font][/size][/font][/size][/font][/size]
[size=\"3\"]Bugs[/size]
  • [size=\"2\"][font=\"verdana\"]No reply to C? And s?[/font][/size]
  • [size=\"2\"][font=\"verdana\"]When Comfort broadcasts counter change >= 128 to 255, this may affect the state of other reported Comfort conditions eg high zone numbers
[size=\"5\"][font=\"Arial Black\"][size=\"5\"][font=\"Arial Black\"][size=\"4\"]Version 5.183 (11 May 2009)[/size][/font][/size][/font][/size]
  • Write to Comfort from Comfigurator - if number of bytes received from Comfort is less than requested by PC, dont send the extra no-value bytes to the PC
  • RS232/Ethernet/USB Transmit Buffer size increased from 240 to 500 bytes
  • Report Sensor state S?NN to UCM
  • TM01 mode works with isolated RS485 module
  • Fixed bug No reply to C?
  • Implemented set sensor command s!nnvv
  • TP query works to get Time programj status
  • fixed BUG Broadcast to modules type was rejected affects SEM, UCM, KT03
  • FIXED bug AM, ER, AR, KL, DB messages sent rubbish characters
  • Doorbell command Dbxx implemented where xx is ID
Bugs
  • Bypass report BY and B? does not work
  • FL reported even when not logged in
  • When Comfort broadcasts counter change >= 128 to 255, this may affect the state of other reported Comfort conditions eg high zone numbers
[size=\"4\"]Version 5.178 (29 Jan 2009)[/size]
  1. Fixed Bug s? Command does not work
  2. Fixed BUG command WD to UCM EEPROM address 0800 hex does not work if EEPROM is 24C256, (for UCM/KNX)
[size=\"4\"]UCM 5.174 (24 November 2008)[/size]
  • Implemented WD write to other UCM EEPROM, RD Read from other UCM EEPROM, WE conformatiom of write to EEPROM, u? Query ID product type, version and revision. Needed for UCM/HDL and other future external UCMs
  • Improved Firmware download
  • Upload Button on UCM will toggle BUSY1 LED when it is receiving date from Comfort.
  • Download Button on UCM will toggle BUSY2 LED when it is sending data to Comfort
  • Improved Upload, Download and Copy button reliability and speed
  • Confirmed problem with Upload/download butons on UCM If Master/Copy shunts are switched, power must be off and ON, Reset will NOT work
  • Firmware download - of any  rejection of firmware download occurs, UCM sends NA01, NA02, NA03, NA04 for different terminating conditions to find out why UD command sometimes fails
  • Firmware Programming improved, can recover from error
  • Implemented u? Query firmware command to support the SCAN for Modules function. Requires Comfort 5.154, SEM 5.156. KP05 1.010, external UCM  5.168
[img]file:///C:/DOCUME%7E1/LUYUNG%7E1/LOCALS%7E1/Temp/moz-screenshot-1.png[/img]
