"Use Branch Actions" in Comfort I Ultra
This applies to Comfort I and Comfigurator 2 only
In Comfort I from firmware 4.233 onwards please check the box \"Use Branch Actions\" in Configuration > Modules & Settings if you use Comfigurator 2. This allows If/Then actions to work correctly for nested If/Then conditions.
For example, see the Response below. If Use Branch Actions is not enabled then the response will not work as expected.
If you have Comfort I Firmware < 4.233 and you nbeed to code aq complex nested If/Then Response, then you are advised to get a firmware upgrade to 4.234 which is the last released Ultra I firmware
If SecurityMode = SecurityOff Then
AutoArm AwayMode
    Else
     If SecurityMode = AwayMode Then
       If AlarmState < Alarm Then
          AutoArm SecurityOff
       End If
      End If
    If SecurityMode = NightMode Then
        AutoArm SecurityOff
     End If
   End If
   If SecurityMode = VacationMode Then
        AutoArm SecurityOff
        End If
    End If
  End If
