Threads: 50
09-02-2009, 07:42 AM
(This post was last modified: 09-02-2009, 07:43 AM by Howser.)
Hi All,
On my home system, after each power failure, I have to logon (via the keypad) to clear the power failure led and that creates the power restored event (at logon time). I thought the system should clear this when power is restored, without manual intervention.
Howser
Threads: 888
As a security system, Comfort deliberately forces you to acknowledge that there was a power failure.
It may be important that there was not a power failure that occured which you did not know of
Threads: 50
So when will the power restore event run, at signon?
Threads: 1
Howser, if you are referring to the red AC led on the keypad, then yes, the led will be cleared (turned off) when the power is restored.
I have just done a quick test on Comfort I firmware Action 4.233.
What is the firmware that you are having?
Threads: 50
Hi Hendy,
I will check the version when I get home. I am talking about AC Restore Response (Location 1847), is that done as the AC is restored, or at signon ( if signon happens hours after AC restore)?
Howser
Threads: 476
The AC Restore Response runs when the AC is restored
