new responde help[
can somebody help on providing the reponse code for the following
Announce Zone + Switch  output 1 (the output is from from the slave expansion panel(REM) 01 this is the one which is currently set to zone numbers 17-24) for 5 minutes latched on
the above will be attached to an on reponse to an external GJD detector which will only activate in the noght during its own internal light sensor
thanks
raj
If you write this response using response wizard, below the response wizard window you will find the response code, i think. You can write down the code and use it.
brilliant i will try
thanks
