Sensor
In each rooms, I need to control lights via movement sensor (which connected to input). However, I need the sensor will not be only triggered by movement but also depend from intensity of room lights. So the lights will be on only when the environment is dark & there\'s movement.
I found that comfort provides LSM. Is it possible to use more than 1 LSM, eg. 1 movement sensor + 1 LSM in each room, as the environment light intensity is different from one room to another.
How to connect many LSM so it can work together w/ each movement sensor?
Regards.
LSM is connected to a Comfort input. It gives an open/close contact to Comfort. The Zone is programmed as a Normaly Open Switch zone type. Hence a Response can check the zone status, if ON (Closed) it means there is light. The threshold of the LSM is adjustable
see www.cytech.biz/manuals.html for the manual on LSM01
Is it possible to use some LSM in each room since there are some rooms w/ different lumen?
How many LSM max. can be used ?
You can use any number of LSM as you like as each is connected to a Comfort Input/zone
Comfort treats the LSM as any other contact or sensor so you can have up to 128  of them max
