The Philips Pronto models 9400, 9600, 9800 can be used with Comfort. A Prontoscript module has been developed for the 9400 screen which is available for download for free.
The new version of Prontoscript for Comfort is now available from the Cytech Website Link
[size=\"3\"][color=\"#ff0000\"]Please note that this is provided free of charge for Comfort and Pronto installers and make no warranties about the script. This is to be used at your own risk.
[/color][/size]
The Comfort.gef file can be imported by Pronto Edit Professional and dragged to the configuration as a new device. the .xcf file is also available for direct loading into Preonto Edit. This script is for the 9400 only but may be modified by others to fit the 9600 and 9800 screens.
The UCM/Ethernet/Audio is required to interface to the Pronto via wi-fi. One of the best news of all is that you do not need the very expensive RFX extenders which provide Rs232 and I/O ports. Use Comfort as your gateway to Pronto. Comfort makes Pronto worth the cost!
In this version the configuration is done on the PC, and not on the Pronto itself so that when power is switched off, the prontoscript variables are not lost
The features of this version are
The Keypad page is shown. The status of low battery, AC Failure, Tamper, Comms failure is shown. The current security mode ie Away, Day, Night, Vacation or Security mode is shown. Use the keypad like a real keypad to arm and disarm the system.
[/color][/size]
- Supports C-Bus, KNX/EIB, Dynalite, Ulti, Rako, Z-wave, X10, Outputs, Do Responses, Counters
- Feedback from C-Bus, KNX/EIB X10, Z-wave, Inputs, Outputs
- Full Keypad simulation with UCM/Ethernet/Audio with microphone and speaker. Use the Pronto like a real keypad and hear the voice menu and record messages or uise as intercom
- Arm to Away, Night, Day, Vacation mode with status
- Supports IP camera (example of Axis camera provided). Other cameras need Prontoscript code.
- Door Station IP camera shows visitor when door station is pressed. Talk to the visitor using the Mic and Speaker on the UCM/Ethernet/Audio
- Shows alarm status for Low Battery, Tamper, Intruder, AC Failure, Comms failure
- Real time Security zone status
- Event log from Comfort can be viewed
