Threads: 7
I need comfort to control lights & home appliance, but finally as master of home automation.
Can Comfort totally control & completely work together with \'DSC\' standalone home alarm ?
What type of best connection will be used then ? RS232 or IR or ...?
Threads: 880
I think the DSC \"stand-alone home alarm\" would not have a Rs232 interface. You can connect an output from the alarm from one of Comfort\'s inputs when there is an alarm
However you can consider removng the DSC alarm and cnnecting the zon wiring to Comfort, as Comfort is a full-featured alarm system. There is no need for a stand alone separate alarm system when you have Comfort. With Comfort acting as the alarm, you have full integration with your lighting, aircon and other home appliances
The responses to each zone activation is fully configurable based on time, or other combinations lof events
