Changing Away Mode Ring Time
Hi...
Anyone know if it is possible to change the Away Mode ringing time to shorter time than current default setting.  How to make a change on it? It’s good if I can have just a pretty short beep so that the whole garden won’t know I am going out. Wink
Thanks.
What you want is not the Away mode Ring Time, it is the siren duration of the 2 sounds in Away Mode to be reduced
To dsiable the away mode siren on the Siren completely, go to Security Types > Siren Types. > Siren Types = Away Armed and uncheck BELL Output\\
To shorten the duration of each of the two sounds, go to Securuty Types > Sound Types > Sound Type = Armed2beeps, set Tone 1 ms and Tone 2 ms to 50 ms. It will stil be loud but may not sound so loud as it wil be shorter
Can it be more shorten on the siren? Can i have something like siren as short as when you want to lock your alarm car?
Sound laugh is ok, but i need the shorten siren.
What I was describing is how to get a shorter siren I suggest you try it out
