I can't download to Comfort by UCM05 or UCM/Ethernet
I was connect Master board with UCM05 and UCM/Ethernet, set ID, set IP...
The IR learn is OK but when I transfer use UCM05 (Port: COM1/Baud:9600/Flow:None, User code : 1234), PC responce : “No response from UCM”.
I transfer use UCM/Ethernet (Ip:xxx.xxx.xxx, Port: 10001) à “Unknow exception while connecting to UCM”.
Perhaps I miss some step, I don’t sure that.
Pleas help me early soon.
Thank you !
For the UCM05, are you connecting using a serial to USB cable? If so the COM port assigned each time may be different andyou should check  which COM port is assigned to the USB device
Which version of Comfigurator are you using and what is the Comfort and UCM firmware versions?
For the UCM05, I am conneting using a serial to USB cable. I was setting COM2/9600/8bit/No parity/None flow on Laptop. I can learn IR but can\'t download or upload.
Comfigurator v2.2.3, Comfort v5.xx and UCM05 v5.xx !
Pleas help me early ! Thank you
You said that you can learn IR. Can you check on IR learner\'s Add New Function window what COM port number are you using? Make sure you are using the same COM port number for your Comfigurator download/upload that can be found under Options > Connection...
The port used for UCM/Ethernet is 1001, NOT 10001.
Check the D9 (red) and D10 (green) leds on the UCM?  are they both blinking fast?
Make sure the UCM Programming cable is NOT connected to Comfort
Yes ! D9, D10 led flast best. I choice exact COM because I can IR learn (add new function is OK). I was connect UCM05 with Master board by J2 (J2A) jamper. But I can download or upload ???
The COM port you select by IR Learning is not related to the COM port you select using Comfigurator. The IR learner and Comfigurator are two different pograms vene though IR learner is launched by Comfigurator
So you may have selected the correct COM port in IR learner but a different port in Comfigurator
Also make sure that there is no other program which is using the COM port when you try to download/upload, like the IR Learner. Only one program can use the COM port at a time
I know ! I can programming PC good. I was set connection on Comfigurator the same INFRARED program. COM port not buzy. I trust all setting is OK.
I use Comfigurator 2.2.3, Masteboard v5.109, UCM05 v 5.164.
I can upload/download to Comfost. I need advice from you or step by step on check system.
Thank you
I guess everything is OK now. If you need any more advice, please let us know on the forum
Sorry ! My english is terrible !
I can\'t upload/download to Comfost. I need advice from you or step by step on check system.
Thank you
