Threads: 219
Being trying to check the versions of the 3 UCM\'s I have in my system.
Assumed I could use u?11, u?12, u?13 respectively to do this via the UCM I/O monitor but nothing comes back.
What am I doing wrong. Obvously the UCM connected to teh PC reports back via the U? command but surely I should be able to get the same info back from the u? command as well.
J
Threads: 262
This needs a firmware upgrade to Comfort as well 5.163 which shall be released shortly
Threads: 219
Are you able to share what the ETA is on this firmware?
J
Threads: 476
Comfort firmware 5.164 has been released to production although it will take some time to go to new customers
We will be uploading the firmware for upgrade probably next week
Threads: 887
02-15-2009, 03:36 AM
(This post was last modified: 02-15-2009, 04:03 AM by slychiu.)
Thats right, the UCMs need a new firmware update to be able to report their firmware version to the u? command. This requires the new flashable UCM PCB instead of the old style UCM with the U1 IC in a socket that you have. We currently do not have Smartfit firmware of the flashable type as there has been no demand for it in several years. Even so that would not solve the problem of the 69 value when heating is off
I have looked through old correspondence - this was actually reported to Honeywell in 2002 as an issue with the Smartfit protocol
