Comfigurator 2.9.9 - 2.9.11 Beta
This is a continuation of the topic from http://www.comfortforums.com/forum20/1088.html which has been closed due to too many threads
The new beta version 2.9.10 is now available from  our website at
https://www.cytech.biz/Default.aspx?cmd=sQ0OYE9X66w%2b0P%2bAcFsmAI3j73Rwtfrj&fileid=203&dcid=4&pageindex=
I downloaded and tried 2.9.10 today and there are still smartfit errors even with the standard smartfitdemo ccl file.  You seem to have fixed some but not all of the Smartfit response errors?
Any advice on what to do next? Wait for the next build?
J
p.s Could we have a \"What\'s fixed in this build\" list so we can determine when to test with our respective configs.
Also I get the following error when clicking on the \"Reminders\" and \"Time Programs\" nodes under \"Schedule\"  when using the smartfitdemo CCL file though doesnt do on my main config that I converted from 2.2.3.
J
ps. Went back to 2.9.9 and it works so this seems to be a regression. Then went back to 2.9.10 again and confirmed it fails.
They say things come in threes.
In 2.9.10 if you select System information from the menu bar  and enter the engineer code you get the error below.
J
Apologies, we still have a problem with the Smartfit Scheduler actions
The Time Programs and Reminders errors were due to the original file having 16 Time Programs (instead of 32) and 8 Reminders (instead of 16) which were not extended when converting to the new cclx format
For the System Information problem, were you using UCM/Ethernet?
We will get the remaining problems fixed as soon as possible as we have a deadline in mid february to get to a release version
Yes I\'m using UCM/Ethernet.
Thanks for the feedback on the other issues.
J
Yes, the UCM/Ethernet does have a problem with Read from Comfort, but not so with the RS232 interface
Would it be possible to have the \"Show Status\" checkbox in the control menu when the \"feedback Type\" is \"Sensor\".  Been trying to check the Temp of SCS 1 in basically anything!
Reports correctly from the Keypad so that part works well.
I couldn\'t see any way of checking the value though in 2.9.10; is there a way?
In 2.2.3 it does show the value and seems to be always zero and I cant do a get sensor value as it says action is invalid (this reported previously on another thread).
Also checked in Wizcomfort but that hasn\'t kept pace with later versions of comfort from what I can see so can\'t display sensor values.   How about you guys doing some work on wizcomfort after 2.9.x is released as would be great to get a new version of this?  If it\'s not being developed any more then what about making and posting as Opensource so at least people can have a go at updating themselves. Smile
J
In anticipation of the arrival of my comfortII panel, I have been busy putting together my config file :-). I decided I would use 2.9x Beta for it (why not!!) might as well.
Here is one prob I noticed, although this may be due to something I am doing as oppossed to an actual bug. Not sure if similar thing would happen in earlier versions of comfigurator.
For example
if flag sunset 0
Then do reponse \"hall light off\" after 180 sec using hall light timer.
Else
Do response \"hall light on\"
I might go back and check this reponse later and find it has \"changed\" to
if flag sunset 0
Then do reponse \"ALL HEAT ON\" after 180 sec using hall light timer.
Else
When I noticed this, I did set all reponses to \"not fixed\" as I thought it might be an issue with this.
Eamon
Can you send your cclx file to support@cytech.biz so we can check if it is a bug or  due to something in your programming?
\\By the way you are using Flag Sunset which I presume is a flag you have defined
There is a built-in Night Time Flag which is set after sunset and before sunrise that you can make use of
12 Guest(s)
