CWM Designer in Vista
When running CWM Designer in Vista, you may get the message,
Component “MSFLXGRD.OCX” or one of its dependencies not correctly registered: a file is missing or invalid.
To fix this problem you have to register the file in Vista
This file should be in WindowsSystem32 If it is not found download or use the attached file
Open a command window (Start> Run> cmd), and type the command (You may need to have administrator priviledges on the computer)
regsvr32 /u Windows/System32/msflxgrd.ocx
(this unregisters the file in case it is incorrectly registered)
regsvr32 Windows/System32/msflxgrd.ocx
(this registers the ocx)
You should now be able to run the program
.zip   MSFLXGRD.zip (Size: 90.94 KB / Downloads: 3)
