In Setup > Options > Files tab
the Config file location should be the location of your ccl file which has been downloaded to your system. This allows WiZcomfort to extract all the information about inputs, outputs, ucms etc that is set up in Comfort
The IFR files location is the location of your IFR folder in Comfigurator. This is usually Program Files\\Cytech\\Comfigurator\\IFR. just click on any .fir file
The IOMAP location is whefre the main configuration file for Comfigurator is found. It is Program Files\\Cytech\\Comfigurator\\iomap.cym
To add on, whenever the ccl file has been modified and downloaded into Comfort, the ccl file must be reselected in the Setup > Options > Files tab of WizComfort, and WizComfort must be restarted. This would then update the configuration loaded on WizComfort.
There is a thrid party Comfort Plug in for the Homeseer software, see http://www.comfortforums.com/forum28/
You will need the Homeseer software
If you have any questions, you will have to ask the developers of the software
My concern is that It isn\'t very user friendly the installation process.
Would it be possible to have a single installation setup file that would create the necessary folders and then the installer would copy or ask the user to copy the CCL and IFR files to their folders.
I think that this way it would be a more professional installation.
The problem with that is that in most cases, the ccl and irf files that need to be used by the user may not be know at the time you install the Wizcomfort software, so they would need to manually copy the required file anyway
