WizComfort Setup > Options
[line]Click on SETUP at the top of the screen and OPTIONS
This is where you select whether Wizcomfort connects by a serial port (UCM/IR) or TCP/Ip (UCM/Ethernet)
If serial is selected, choose the Port 1 to 16
If TCP is the connection method, enter the IP address and the port for the UCM/Ethernet
[color=\"red\"] In the box BIND TO THIS IP ADDRESS, enter 0.0.0.0[/color]
The Master Security Code is the user code that will be used to login automatically
[line]
For the UCM IP Address, can it accepts host name instead of just IP Address?
The network address must be an IP address in the form eg 10.0.0.100, and not a URL like http://cytech.net
Please confirm that Wizcomfort accepts IP Addresses such as Names (http://intelicontrol.no-ip.org) instead of xxx.xxx.xxx.xxx IP address.
Tks
Just tested it. Seems like it doesn\'t work for no-ip.
