Threads: 62
If I want to upgrade to 5.145 I need a MPU01 for my Main unit. I have three Slave units each with a extension board to give me 64 zones in total.
Just to confirm, I need MPU01\'s for each unit right? If upgrading the Main unit via UCM05 will it upgrade the Slaves as well? What is the easiest to upgrade all 4?
Ingo
Threads: 62
All my units are pre 5.100 so I will get MPU01\'s for all of them. Flashing the Main board is no problem, I understand the upgrade procedure. There is however no mention of the slave unit upgrades. Do I upgrade the main unit and then transfer the MPU01 to the slave? Doing this 4 times will upgrade all 4 of them or should I somehow transfer my UCM05 to each device individually and upgrade them one at a time?
Threads: 885
You have 1 Comfort and 3 Slaves, so you will need 1 MPU-ULT and 3 MPU-SEM
MPU for Comfort and Slaves are different as the firmware for Comfort and slaves are different from each other
Once you plug in the MPUs to their respective boards, you do not need to upgrade them further, as they will have the latest firmware already
It is only in future when new firmware is available that you can use the UCM05 to upgrade the Flash memory on your new MPUs
Threads: 62
Thanks, I\'ll amend my order accordingly.
Ingo
Threads: 35
Are there any issues with running the main board on the current version and not updating the slave? the Main board is currently 5.121 and the slave is 5.033. I will upgrade to ULT 5.145 if it won\'t cause problems and get a mpu-sem to do the slave later.
Threads: 35
So because it is not SEM 5.081 to 5.084 and the main board is higher than 5.078 it will be okay.
Threads: 35
only as confusing as the document!!
