After upgrading Comfort Action 4.221 to 4.234 (PC01-001E Rev E) system was functioning properly for a couple of weeks, then suddenly (for no reason at all) system start resetting itself.
This never-ending loop of resets starts within a few minutes after normal reset or engineer reset or power reset. After a power reset I have managed to download the configuration to Comfort just to make sure that settings are correct. Unfortunately, it didn\'t solve this problem, after 30min system reentered the reset loop. The only way to fix this problem was to revert to the old 4.221 chip. The older chip with exactly the same configuration does not enter the reset loop. So now we are stuck with the older firmware, please advise.
See the event log below, all events related to server loop have time 00:00
06/14 00:00 Unknown Event #3019
06/14 00:00 Reset
06/14 00:00 Sign in - User #
06/14 00:00 Mode Change #Security Off
06/14 00:00 Reset
06/14 00:00 Reset
06/14 00:00 Reset
06/14 00:00 Reset
06/14 00:00 Reset
06/14 00:00 Reset
06/14 00:00 Reset
06/14 00:00 Reset
and so on .........
06/14 00:00 Reset
06/14 00:00 Reset
06/14 00:00 Reset
06/14 00:00 Reset
06/14 00:00 Reset
06/14 00:00 Reset
06/14 00:00 Reset
06/14 00:00 Reset
06/14 00:00 Reset
and so on .........
