Can not access system
I did not identify keybad at Module Configuration and download it to system ,
So i could not later download any modification because i can not enter Engineer code .
How to solve it?
.ccl   Demo.ccl (Size: 71.08 KB / Downloads: 3)
I see that you have set number of keypads=0
There is a way to fix this
[size=\"2\"][color=\"red\"][color=\"black\"][size=\"1\"][size=\"2\"]
[/size][/size][/color][/color]
[/size] 1 Start Comfigurator
2  Select [Transfer] [Monitor I/O]   so that it is ticked.
3 Select [Transfer] [System Information]
4.  If asked for a password enter a normal user code,   not the engineer code.
The system info window pops up,  if it does not then your cannot do anything until that issue is resolved.
5 Click [OK]  on the system info window to get rid of it.
6 Now in the long one line  ( command line field of Comfigurator) type  [highlight= rgb(255, 255, 136);]DA5C01[/highlight]  followed by carriage return. (This means Do Action - Enable Engineer)
You should see the following in the log window.
Tx: <STX>[highlight= rgb(255, 255, 136);]DA5C01[/highlight]<CR>
Rx: <STX>PS01<CR>
Rx: <STX>RA00<CR>
The PS01  is the system reporting that engineer code is now enabled.
7  Now do a standard [Transfer] [Download PC> Comfort], enter the engineer code.
[/color]
[/size]
i did follow your instruction but it PS didn\'t changed  (attached screen shoot)
please note that my system is ULTA II and the file that i did upload with missing Keypad was mistakly chosen Comfort PRO ( if that will make any difference)
so waiting for ur comment
thanks
You seem to have a problem with the RGB255,255 characters which you entered
Just type DA5C01 in the window
work like a charm
thanx
Thats good, make sure you use the Comfort II template now, and set keypads to 1
