Threads: 8
I have 1 SCS in the system. I am successfully announcing the temperature in the home control menu using sensor 8. When I try to use Comfigurator to \"Get Value, Sensor register 8\" in order to copy to a counter, I get an error that sensor 8 is invalid.
Threads: 8
Thanks that works nicely. However if I want to set a sensor feedback in Home control it does not allow me to select a particular sensor. Is this because I only have one SCS in the system and it automatically assumes it is Sensor no 8?
Secondly when I try to display the temperature in degrees C I find that the CWM applet designer will not let me set non integer steps in the value list as is shown in the CWM manual. Will I have to edit the HTML?
Threads: 880
This is a bug in the sensor feedback feature in the Control Menu in the beta Comfigurator version. Thanks for discovering it. We will get it fixed in the next release
We will investigate the matter with the CWM designer
