Word lists
I\'m user of a comfort PRO, is it possible to add the Spanish residential in the word list for file system 18?
Perhaps the Spanish distributor Carlos Ask something about that today to someone.
Unzip the attached zip file to the Comfigurator folder.
When you have a new file for Comfort I, go to Modules and Settings > Wordlists. you should see Spanish Comfort I. This is only the word list in Configurator. It must match the Spanish vocabulary in your Comfort for it to work
.zip   spanish1voc.zip (Size: 3.19 KB / Downloads: 6)
I did it but it doesn\'t works. In my case I have a comfort Pro (file system 18) with the Spanish language. I\'m the one who traslate the english to the Spanish in 2002.
I trying to upgrade and update my comfort. I used the configurator 1.6 with my old UCM but when I try to transfer the information to the comfort a message appears asking for a code number. Then I ask to an installer and he told to used Configurator 2.3
After using configurator 2.3, the system works but doesn\'t speak.
The only thing I want is to use Spanish residential when you use file system 18.
I hope you can help me. Thank for all.
Vicente
Vicente
I don\'t understand why you did not have the Comfort I Spanish residential wordlist as it used to be included with Comfigurator older versions. Were you not able to select Spanish words at all before?
Can you tell me what you downloaded into Comfort, and what you are trying to upgrade. The wordlist files I gave were for Comfigurator only to allow you to select Spanish words in Zones and Control menu, and shhould not cause the voice to be lost.  You did not try to do a vocabulary download, I hope.
Please provide all the information so we can understand what happened
Also what is your UCM and Comfort version
I have comfort Outside 4.222 and UCM 5.02
I add some new zones and detector and i wanted to change some responses, this the reason to use comfigurator, my first progamings was with csxpress in 2002.
Now i bought to Carlos a UCM ethernet but I didn\'t install it.
What I want to do is \"play\" with configurator in programing but using the same comfort system. Perhaps in short future I\'ll change to confort II if I see the adventages.
Ragards
Vicente
Using comfigurator 2.3 with file ssytem 18 the option of word list are:
- Standard residential
- Chinese residential
- UK residential
- Pagewatch
- Australian residential
I would like to choose Spainish residential too as an option.
Vicente
If you unzip the 3 files in my original post and copy them into the Comfigurator folder this should allow you to see Spanish Comfort I in wordlist for Comfort I. See the screenshot
I unzip again the files and I don\'t see the changes. I unzip in the follow folder:
C:\\Program Files\\Cytech\\Configurator
The first time I copied the files a message appears telling that you were rewriting the same files (with the same size).
I look for another folder but I think this is the right one.
Thank for your help.
Vicente
Are you sure you sent the right files?
I tryed a some times again and it doesn\'t work.
Vicente
The files are correct
What are the wordlists you see in the wordlist window compared to my jpg file that I showed?
Have you selected Comfort I PRO?
