Request - Keep Responses Fixed after editing
In the next version update of Comfigurator - can we keep the response fixed eg the same number after we edit it if the Fixed check box is ticked before editing?
Stuart
Response numbers may have to change due to editing.  Response slots take up 8 bytes. A response may take up several Response slots depending on its length
Hence if you add codes to a Response it may run over to the next Response slot which may be fixed so it has to find a new number where there are enough slots to fit in Hence when yoou edit a Response, it becomes unfixed. You will have to re-fix it after editing
