Threads: 62
When I came home last night I saw a Battery Controller Failure alarm on my keypad. When I did a battery test it keeps on giving me this error. I then switched the AC off and the whole system just died. I have 1 Master and 3 Slaves all with batteries and none of them worked. To fix this I had to press SW5 ( I think) on all 4 units to get the system running again - on battery power initially. After switching the AC on everything was fine again.
My question is, why do I have to reset the system manually to get it going again? This only happens once in a while, switching the AC on/off usually don\'t have any effect on the system.
Ingo
Threads: 62
I measured the battery voltages about 30 minutes after switching the AC off and they all read around 13.5v. I will keep an eye on the system to try and see what actually happens when this occurs. The problem is that it always happens (both times) when I am not at home.
Threads: 262
13.5 Volts seems to high for the battery voltage. That is normally the voltage when it is being charged. A normal bettary voltae with be 12.0 to 12.5 V
Threads: 62
I also measured it when on charge - 13.8v give or take a few mV. The load is not very much, I have 14 PIR\'s spread over 4 panels, the rest are door and window switches. I can measure the current drawn but that will only confirm why the voltage is so close to the charging voltage even after 30 minutes on batteries. I do not suspect the batteries at all.
Threads: 2
When I start my Comfort without battery It has been a battery warning. When I reconnect the battery the warning still remains in the keypad . How can I \"reset\" the warning battery?
