Wireless alarm control/garage door operation - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Wireless alarm control/garage door operation (/thread-905.html) |
- Campbell - 01-02-2008 Can anyone recommend a secure wireless interface for Comfort to a/ Arm/disarm comfort to/from away mode at the same time closing/opening the garage door \"Hormann\". HAs anyone managed to use a Hormann or similar garage door control for this. thanks Campbell - admin - 01-02-2008 Visonic www.visonic.com have a range of wireless handheld transmitters and receivers. The receivers have 1 to 4 hardwired outputs which can be connected to Comfort Inputs to trigger responses for arming and disarming, and to open the garage door. I am not familiar with Hormann, I would expect that it can be opened or closed using a relay contact - palmlodge - 01-02-2008 Ive done this with a ã3 ($6) relay straight to a comfort relay output. Very easy. Also, with a magentic door sensor, Comfort knows if the door is open or closed - and will even self close when arming to away etc... http://palmlodge.com/lookup/Comfort+to+Garage+Door - Campbell - 01-02-2008 Many thanks....This could fit the bill.... I have a few Comfort Relays from playing with Camera switching back in 2000/2001 and if I can find these, I can use them for Comfort to control the door. I\'ll try to get the Hormann diagram to see where I can wire in so that the Horman remote can switch the alarm on/off....I could use x10...but not secure. thanks again Campbell - palmlodge - 01-07-2008 Dont even think of using x10 that can control access :-) Most garage door openers are 24v so just ensure your relay is up to the task. |
