Setting up Date/Time reports - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Setting up Date/Time reports (/thread-901.html) |
- EverHome - 12-30-2007 Hi, How do I set Comfort up to send regular DT reports through RS232 interface? Regards, David - admin - 12-30-2007 The DT message is issued automatically when the time or date is changed. You can also request the date and time by entering DT from the UCM RS232 interface.The UCM will reply with current date and time However there is no mechanism to get the UCM to automatically send the DT message at a specified interval - EverHome - 12-30-2007 Without doing anything specific I am receiving date/time values from Comfort every hour from RS232 interface. - admin - 12-31-2007 You are correct, I forgot that Comfort sends the DT message every hour on the hour. Is this what you need? |
