Firmware version compatibility - Printable Version
+--- Thread: Firmware version compatibility (/thread-865.html)
- Guest - 11-18-2007
I Have a comfort system that was purchased back in 2000, I believe the serial number is A002068 (it\'s on a white label in the middle of the PCB)
It is currently running firmware version 04.115 Outside.
What is the latest firmware version that is compatible with this board?
Alan Shields
- admin - 11-19-2007
That is a Comfort I system. The latest firmware is Action 4.234 (Ultra I) with File System 24.  See the firmware history in http://www.comfortforums.com/forum60/824.html
When we launched Comfort II, we made available the upgrade to Ultra I at the same price as PRO. Dont forget to order the U4 for FS24. You will have to do a File Conversion to FS 24 in Comfigrator for your old CCL file
You could also get an upgrade price for Comfort II to upgrade your system, which is recommended
