ID indication - Printable Version
+--- Thread: ID indication (/thread-831.html)
- hotohori - 10-19-2007
If I need 24 zone/output how to set the ID code?
If the mainboard having the first 8 input & output do i need to short all the ID code or dont short it?
- admin - 10-20-2007
I assume you have 1 LEM01 and 1 Slave SEM01 to give 24 inputs and outputs
The Comfort II Main board has no ID. The ABCD shunts next to the U11 IC should be left open
The SEM ID should be 1, ie A,B,C,D should be shunted
