Sunrise/Sunset Times and Daylight Saving - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: These Forums (https://www.comfortforums.com/forum-1.html) +--- Forum: NEWS & Announcements (https://www.comfortforums.com/forum-25.html) +--- Thread: Sunrise/Sunset Times and Daylight Saving (/thread-796.html) |
- ident - 09-18-2007 Comfort firmware 5.121 and above will have Sunrise/Sunset times which are downloaded from Comfigurator 2.2.3 based on your location, city or coordinates. There will be a Sunrise and Sunset Response which can perform actions at the correct times, and a Night Flag is set after sunset to allow checking by other actions. This takes into account Daylight Saving time. In fact, Comfort will automatically adjust the clock for Daylight saving time on the correct days, eg Last Sunday of October and April, or the appropriate dates in other countries. The Sunrise/sunset screen in Comfigurator is show below ![]() See the topic http://www.comfortforums.com/forum20/1004.html for aan explanation of how Sunrise and Sunset times work with Daylight savinf - garym999 - 10-16-2007 I can see the \"Night time\" flag under Actions, IF, system parameters but where are the sunrise and sunset responses? Also you mention DST, I assume this now means that I no longer have to have a timer program to check the date etc. Comfort will change automatically? Using Comfigurator V2.2.2 PS used this http://geodaisy.com/ to get my exact coordinates in the UK - admin - 10-17-2007 Our changes are ahead of Comfigurator. The Misc Events for Sunrise and sunset are not added in yet. That will be in the next interim release. In the meantime, you will have to use the Locations Menu in Engineer Menu 7,4,3 to enter these values Addendum Sunrise and Sunset Responses have been implemented in Comfigurator 2.2.3, in Events > Misc Events - garym999 - 10-17-2007 And the locations are? Also do I still have to test if we are in DST or not? Or will Comfort now update its clock automatically? - admin - 10-17-2007 The Locations are For Sunrise - 776 for the Lower Byte of the Response Number and 777 for the Higher byte of the Response number For Sunset - 778 for Lower byte Response number and 779 for theh higher byte of Rresponse number The Locations are 8 bits which is why you need two locations to enter a Response number eg if you want to enter Response 260 into Sunrise Response, Location 776 = 4 Location 777 = 1 1 x 256 + 4 = 260 Engineer Menu 7,4,1 announces \"Enter Location and # key\" Comfort will adjust its clock automatically for Daylight saving on the appropriate day at 3 AM, you will not have to do it - palmlodge - 10-18-2007 Any reason why 3am ? Strictly speaking, UK clocks change at 1am on the day. Also, the old timer program which ran twice a year for DST adjustments - we no longer need this correct ? - admin - 10-18-2007 3 AM was just chosen as a quiet time when nothing much should be happening Different countries have different times for the change anyway The old Response which was used in the Time Programs must not be ised now as that would cause an additional change |
