comfort output to control high voltage appliance - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: comfort output to control high voltage appliance (/thread-686.html) |
- salizam - 07-01-2007 hi, what spec of relay should i use to control a 240vac 15amp water pump wall switch. thanks. - Guest - 07-02-2007 Maybe you could get the Heater Control Module? |
