Best way to know the state of a flag - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Best way to know the state of a flag (/thread-672.html) |
- ruirego - 06-19-2007 What is the best way to know the state (if it\'s 1 or 0) of a flag? Thaks Rui - Guest - 06-19-2007 Set it as the status in the control menu? What do you aim to achieve? - ruirego - 06-21-2007 Thank\'s! It was just to test this response: [indent] If Flag Flag01 <> 0 Then Do _sim_presenca_02 [p0_luz cozinha_off] Do _sim_presenca_04 [p1_luz cozinha_off] Do _sim_presenca_06 [p1_quarto susana_off] Do _sim_presenca_08 [ex_varanda_off] Do _sim_presenca_10 [ex_jardim suite_off] Do _sim_presenca_12 [ex_muro circuito 1_off] Do _sim_presenca_14 [p1_quarto srê conceição_off] Clear Flag Flag01 End If [/indent] The flag is set when the system is armed in vacation mode. Before this response all the lights in vacation mode remain on after the custemer disarm the system. Rui - Guest - 06-21-2007 Rui, If you are using a flag to determine whether in vacation mode before deciding to execute responses or not, wouldn\'t it be easier to set it such that: If SecurityMode = VacationMode Then Do _sim_presenca_02 [p0_luz cozinha_off] Do _sim_presenca_04 [p1_luz cozinha_off] Do _sim_presenca_06 [p1_quarto susana_off] Do _sim_presenca_08 [ex_varanda_off] Do _sim_presenca_10 [ex_jardim suite_off] Do _sim_presenca_12 [ex_muro circuito 1_off] Do _sim_presenca_14 [p1_quarto srê conceição_off] Clear Flag Flag01 End If - ruirego - 06-21-2007 Hi, Here is the scenario: On the vacation programs I have some responses (see attach). This responses are just EIB light groups. When the system is in vacation mode this light groups are turn ON and OFF randomly. Until here everything OK. The problem was - when the customer arrives home and disarm the system, all the lights that where ON remain ON - slychiu - 06-26-2007 Your solution should work then When you arm to vacation mode, you set the flag by the vacation Mode response when you disarm you check the flag and control the lights if it is on. That is a good pieve of programming Does this work? - ruirego - 07-02-2007 Yes, it works fine. |
