Comfigurator Crash - Printable Version
+--- Thread: Comfigurator Crash (/thread-5980.html)
Comfigurator Crash - cc_uk - 06-15-2026
Hi  I am using Comfigurator 4.0.4.0 on Windows 11 25H2
Very often after connector to the Comfort CM9001/A I get a crash:-
Battery Monitoring :
System.IndexOutOfRangeException: Index was outside the bounds of the array.
  at Comfort.Form1.GetBatteryVoltage(Configuration configuration)
When this happens if I look under Modules -> controller I see Battery voltage 14.19  and DC Voltage as N.A.  usually if I scan for all modules it will then work and show DC Voltage 14.97
RE: Comfigurator Crash - Home - 06-16-2026
(06-15-2026, 07:21 PM)cc_uk Wrote: Hi  I am using Comfigurator 4.0.4.0 on Windows 11 25H2
What components are you using and what version of firmware are they on ?
RE: Comfigurator Crash - cc_uk - 06-16-2026
I have a CM9001/A running 8.034
two KP04A keypads running 7.016
I UCM running 7.225
1 SEM running 7.142
1 8 button SCS running 2.004
