iOS App 1.8.7 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: iOS Apps (https://www.comfortforums.com/forum-122.html) +--- Thread: iOS App 1.8.7 (/thread-5833.html) |
iOS App 1.8.7 - slychiu - 03-18-2026 The Comfort iOS app was notr able to work with iOS 15 and above, When you select a jrlccip file to activate, the app closes immediately. This is due to some functions becoming unsupported. There is a fix in app version 1.8.7. This is in beta. To test this, please go to the link below to singn up as a tester https://testflight.apple.com/join/xgWjoSmv The other changes are; [*]Added a named black color to the asset catalog to guarantee black background on all devices [*]✅ Gap fixed on iPhone 16 Pro Max [*]✅ Layout restored correctly on iPhone XR [*]Removed unused Camera Tab The email to the phone does not work anymore. The jrlccip attachment is removed by Apple. The best way to send your converted .jrlccip file to your phone is [*]Go to icloud.com on PC → sign in [*]Click iCloud Drive [*]Upload the .jcrlccip file directly [*]On iPhone → Files app → iCloud Drive [*]Tap the file → should prompt to open in Comfort G2 Phone [*]Also, when you press the IMPORT button in Settings to load a jrlccip file (instead of tapping the jrlccip file), you can browse to other folders on the phone to find the file (eg Downloads) instead of being restricted to the App folder which is where the email attachment was sent [*]Please feedback any problems or results RE: iOS App 1.8.7 - slychiu - 03-24-2026 Comfort G2 app 1.8.7 has been released. When you do the update it will show as 1.8.2 in app store but after you update it will show the version as 1.8.7. There was mixup of the version number during sum=bmission to the appstore |
