Comfort2MQTT and UCM/PI - Printable Version
+--- Forum: Comfort with Home Assistant (https://www.comfortforums.com/forum-143.html)
+--- Thread: Comfort2MQTT and UCM/PI (/thread-5659.html)
Comfort2MQTT and UCM/PI - bmistry3 - 08-25-2025
Hello Folks
If one already has the UCMPI running and using Node Red and talking to HA, what are the advantages of removing it and moving to Comfort2MQTT
I assume biggest advantage is you remove the UCMPI hardwar from the equation
Bhupendra
RE: Comfort2MQTT and UCM/PI - slychiu - 08-25-2025
My opinion is. Home assistant is better supported with more integrations. It is also easier to set up then Node Red, and has better User Interface with the Dashboards. Unfortunately support for UCM/Pi is not available anymore
