Config 2.1.2 Bug in Reminder Message specification - Printable Version
+---- Forum: Comfigurator 2.X (https://www.comfortforums.com/forum-67.html)
+---- Thread: Config 2.1.2 Bug in Reminder Message specification (/thread-564.html)
- Ian Clarke - 04-23-2007
Hi Malcolm,
in 2.1.2 the distination of reminder messages,  ie where they are played, is broken.
It it not possible to specify \"All Keypads\"  it gets changed to ( 51 which is door station 3).  If you have no door station 3,  you do not hear any message anywhere.
Also \"All Keypad and All Doorstations\" starts of as destination 0,  then if the action is edited again by double clicking it, the value changes to 32, which also does not work.
What are that correct values for \"All Door stations\", \"All Keypads\",  and \"All door stations and Keypads\", so that a user may put these in manually.
Thanks to Rod McCleod for spending the hours identifing this bug.
Regards  Ian Clarke
This is a work around for the reminder message bug.
It is possile to use the edit response manually to define the required desitination of the messages.
For All door stations and keypad the code is 0
For all door stations the code is 32
For all keypads the code is 64
For keypad 1-8 use code 1-8 or 65-72
For door stations 1-3 use code 49-51
This information is found in the Actions manual for Action code 133.
Hope this helps.
- ident - 05-05-2007
This has been corrected in 2.1.4 (beta)
Thanks for your feedback
